Results 1 to 14 of 14
Thread: Coil change time.
    Euro Addiction Advertiser Mike@Ringer-Racing.com has an average reputation Mike@Ringer-Racing.com's Avatar
    Default Coil change time.
    Got tired of having to pull the DIS coils off the VC when I wanted to change the spark plugs, not easy when in a hurry.
    So I decided to make the change and mount them next to the catch can, really only place I could put them. Then use spark plug wires over to the VC.
    A little prep work to get the car running again and so that its ready once the new built trasnsmission is finished.
    Coils on the VC
    Now with them mounted near the catch can.
    Spark plug wires.
    Still need to put on some wire seperators and paint the mounting brackets. Just glad to be able to just swap spark plugs in a hurry again. Plus now I can put one of my CF coil covers back on the VC.
    Passionate a4spoolin has an average reputation a4spoolin's Avatar
    hardyston,new jersey
    looks real good i like the idea. taking off coils can sometimes be a pain espcially when you doing it all the time. were you previously having a problem with melting the coils with the top mount turbo?
    Cat In The Hat JEmm has an above average reputation JEmm's Avatar
    Looks really clean man. Any new numbers or 1/4 times?
    -Jeff
    B5 A4 1.8tqm
    chip, low, loud
    Avus's for now...
    N.E.R.D.
    No, never had a problem melting stock coils and I ran the ATW coils for about 6 years with the top mounted turbo setup.
    Quote Originally Posted by JEmm View Post
    Not yet, still waiting to get the transmission back.
    O ok nice. What are you doing with the trans?
    -Jeff
    B5 A4 1.8tqm
    chip, low, loud
    Avus's for now...
    N.E.R.D.
    Cryo/heat treated gears/input shaft, plus a machine shop is working on making a cuff that will take the place of 5th gear.
    Wow, nice. Trying to make this the last trans rebuild? hahaha
    Looking forward to seeing what your car puts down when your all done!
    -Jeff
    B5 A4 1.8tqm
    chip, low, loud
    Avus's for now...
    N.E.R.D.
    Doing everything I can to see if I can make it last.
    Moderator dougyfresh has an average reputation dougyfresh's Avatar
    Jul 2010
    Connecticut
    Quote Originally Posted by Mike@Ringer-Racing.com View Post
    You are getting rid of 5th gear?
    The new coils look nice. Did you fab that all up yourself or does someone sell that set-up?
    -Doug
    2002 A4 2008cc GT-3076R turbocharged Avant
    397awhp/371awtq on straight 93oct and 96*F ambient
    tuned by Autospeed Performance
    It is the 034 DIS coils and their bracket kit. I had to add another bracket on the left side to hold their bracket to the tower and a tall strap from the battery tray bolt on the firewall to hold the other end.
    These coils and this bracket kit from 034.
    Yes I am getting rid of 5th gear completely. This shop does cuff setups for the honda transmissions when used for drag racing.
    Jul 2010
    Connecticut
    I like that coil set-up, Mike. Good job.
    When are you going to the track next? Waiting for the trans to be rebuilt?
    -Doug
    I was hoping to get it to the track this month, but that isn't going to happen now. The guy that was working on my transmission just called to tell me that he doesn't have the time since his job just got very busy.
    Now I need to find someone else to rebuild my transmission for me. Time to call up Matt.
    send the tranny over here to level ten. shpping trannies across country could get expensive though
