so the car does not shift into tip. it goes into the position but shifts by itself like normal. nothing lights up on speedo either about tip tronic just regular prnd432
HELP please!
HELP please!
E46 Sedan
Not slow Enough.
02 Audi S4
-Jeez this lady's forehead was larger than my windshield.
Do you have a VAGcom to scan for any codes stored under transmission?
Don't quote me on this but there like the magnet things that are triggered when you put the car in tiptronic I hear they slip out of place sometimes... they sit right under the shift lever area. I believe I read that on az at somepoint very common with the c5 A6's.
^sorry for the bad grammer writing quick from droid
it doesent appear to have any codes for trans but i will def double check, i have a snap on solus pro, which can do miracles like disable electronic parking brakes and stuff. So ill give that a try,and i posted on audizine also but no replies yet
E46 Sedan
Not slow Enough.
02 Audi S4
2004 B6 Avant USP-KO4 Turbo w/ECU Upgrade/Chipped 4 Prog., APR Sport Cat-Back Exhaust Sys., AWE FMIC, Turbo Inlet Hose, Smoked Angel Eyelights, Pro Dry S Stage 2 Air Intake Sys., Vent Pod Boost Gauge, Smoked Tails, Sidemarkers, Kenwood Navi w/ Bluetooth, Sirius Sat.,rear camera, Rims and all Chrome on body matte black, Forge Hybrid BOV / Dropped, Stg.4 Porsche Cayenne Brakes
1999 Audi A4 2.8 SUPERCHARGED-Eyelids,Rs4 Front,Kamei Grille,S4 Rims, Milltek Exhaust My Website-http://4ringaddiction.com
N.E.R.D.
Im going to detail it today so ill def check out what it is! if anyone wants to swing by wayne shoot me a PM
cuz im there allllll day
E46 Sedan
Not slow Enough.
02 Audi S4
this couple be a couple isssues. it could be your prndl control as stated a missing magnet or your tiptronic switch or your tcm. without measuring value blocks and some diag theres no knowing.
N.E.R.D PREZ
ARNY ADDICTION
DUB TECHY
IM ARNOLD PALMERbut im told i look more like john daly
the old-guy-with-no-more-braincells-member....what??
hug a fat guy and youll feel better
GLI clubmember#001
i found the magnet today, but no crazy glue so i didnt glue it yet. Changed cam position sensor, so it revs and everything just fine compared to sometimes it wouldnt even give me gas or w.e Now i have a vacuum leak somewhere, so i gotta bring out my smoke machiene to check it out where its coming from. Anyway i started cleaning interior at like 9 and finished at 4 =( fml.
Can anyone tell me whats the noise at the end of the revs? Its like a metal on metal chattering =-(
Sorry for the shitty quality but you still hear it at the end of each rev.
[ame]http://www.youtube.com/watch?v=xAYO8TG2oP0[/ame]
E46 Sedan
Not slow Enough.
02 Audi S4
You make it seem like I am always wrong hahaha jk bro!
To be honest man I can't hear shit haha. You seem to have focused the camera on the Cat/Turbo Area is that where the noise seems to be coming from? What RPM's does the noise become noticeable? Possible shaft play in the turbo (but thats taking a stab in the dark)?
hm, well its like right there honestly, its sometime after 2k rpms, thats exactly what i thought too. Hm, honestly that could be it, im not sure though, can it still be it if its only at the end of each rev?
EDIT: Ill try to take a more detailed video of it tomorrow
E46 Sedan
Not slow Enough.
02 Audi S4
check your power steering fluid level. does it only happen when free revving the motor??
maybe power steering pump,turbo,trans. not enough to go on bud.
N.E.R.D PREZ
ARNY ADDICTION
DUB TECHY
GLI clubmember#001
i dont know about when driving it because its not registered or anything. Its definately not the trans, its probably the turbo, which kinda makes me happy, cuz ko4 will be the upgrade if anything. Or maybe even gtxxxx
E46 Sedan
Not slow Enough.
02 Audi S4
im not 100% sure honestly, but i most likely will be tomorrow. need to fix some boost leaks other bits.
Need to do brakes because those things are shittaay. Check all fluids and probably need to do like a fuel flush, idk how long its been standing!
Im going to start using 91/93 only!
E46 Sedan
Not slow Enough.
02 Audi S4
its boost/vacuum leak, because when you hit the gas and it comes back down it drops tooooo low and has a rough idle for a seccond.
I just thought of something else for that noise. How about a shitty cat? could def be it! Need to check all that out.
Anyone want to do me a small fav and like pm me so we can bs about some basic modding? Wont take too long lol
E46 Sedan
Not slow Enough.
02 Audi S4
-Jeff
B5 A4 1.8tqm
chip, low, loud
Avus's for now...N.E.R.D.
Cool, ill shoot you a pm now =D
E46 Sedan
Not slow Enough.
02 Audi S4
