Results 1 to 19 of 19
Thread: possible broken motor
    Passionate a4spoolin has an average reputation a4spoolin's Avatar
    hardyston,new jersey
    Default possible broken motor
    yesterday on the way to work just doing some casual driving no boosting or anything then all of a sudden a terrible knocking starting to come from my motor. i look down to the cel flashing. i immediately check and my sure my clutch and trans is good since i just installed the new clutch 500 miles ago. those were fine. i was only a few miles from work and knew the damaged was already done so i drove the last few miles.
    i work at a goodyeaer tire store so when i arrived i scanned the car and came up with low signal on maf, and no activity from rear o2 sensor. neither of those would cause a flashing cel. well i got it towed home and took any other look today. the knocking is definetly from the motor and not the trans so i quickly pulled the valve cover see what it looks like and everything was fine. drained the oil and filter ran a magnet through it and picked up some metal flakes. since im now assuming its a spun bearing i decided to pull the front clip off and get ready to pull the motor.
    i took the timing covers off and noticed my tensioner was very very loose, so i was like shit, timing is messed up prob tapped some valves. im extremely pissed at this cuz i just did the timing belt and water pump in march not even 6000 miles ago. well i spin it over to line up the timing marks and the engine is in perfect time. weird right? when i spin the crank its extremely difficult. so something is sticking or bent or something.
    well this is where i am right now and will be doing further diagnosis after work. ill be doing a compression test and leakdown test see if any valves are bent. and my friend is bring me a scope so ill throw that into the cylinder and oil pan see if we see anything unsual. maybe built motor sooner than i thought
    heres a short clip of what she sounds like. it sounds nasty
    [ame="http://www.youtube.com/watch?v=Pwgt5U3Itwg"]http://www.youtube.com/watch?v=Pwgt5U3Itwg[/ame]
    well im about 98% sure i spun a bearing. i started tonight pulling stuff off the motor preparing to pull it out. i ordered a engine hoist and stand hopefully its here by the weekend so i can pull it out and tear it down. im thinking about buying the built block package that 034 motorsports sells, going with the 2.0 stroker kit and over bore and with a gt3076 turbo. not dead set with the turbo yet i gotta look into the power it makes and see if my clutch will hold.
    .gif Bomber
    justin is a well respected and helpful member of Euro Addiction justin is a well respected and helpful member of Euro Addiction justin is a well respected and helpful member of Euro Addiction justin is a well respected and helpful member of Euro Addiction justin's Avatar
    damn not good man! Get in touch with Mike@Ringer... IIRC he has done some great builds for the B5.
    Yea man I'm gonna hit him up now. He was really helpful when I ordered my clutch and def knows this motor better than anybody else. I'm looking to build a 2.0l stroker with 400awhp see what he can do for me.
    I got everything disconnected except for the axles and mounts so ill be pulling the motor and trans tonight teardown will begin tom.
    Interested to see what happened with the motor. Let me know if you need a hand
    thanks joey. i think the only thing i need right now is a reputable machine shop in the area, so if you know any let me know thanks
    Euro Addiction Advertiser Mike@Ringer-Racing.com has an average reputation Mike@Ringer-Racing.com's Avatar
    Shoot me an email when you want prices on parts. If you want the 034 engine build you can get that thru me too.
    North East Region Dubs
    03b6avant is on their way to something great 03b6avant is on their way to something great 03b6avant is on their way to something great 03b6avant's Avatar
    CHESTER, NY
    Quote Originally Posted by a4spoolin View Post
    speek with Pat@Redline speed works. They are in Jefferson or Wshington NJ i think. I spoke with Pat yesterday about possibly putting my motor back together.
    Thanks man, ill look into them. If they are in jefferson that five mins from my house. Mike ill send you an email later tonight and figure out what I can do. The motor should be coming out tonight if the rain isn't too hard, then ill pull the oil pan off and look and make sure its a spun bearing.
    Well got some good and bad news. I pulled the motor last night and jiggled the flywheel and pressure plate assembly and iT moved. Apparently after using lock tight and a torque wrench the flywheel bolts still found a way to come loose. So atleast I don't have to drop tons of money to rebuild my, but my car is still slow lol.
    So the only thing I can say from this experience is if you just had a clutch and flywheel installed and your car starts sounds like a diesel and its knocking, chances are its a loose flywheel. The weird thing was I didn't feel I vibrations in my clutch pedal, that's one of the main reasons we thought it was in the motor.
    .gif Bomber
    That's great news! It may still be slow but you just saved yourself some money for now haha
    CHESTER, NY
    thats great news
    Moderator dougyfresh has an average reputation dougyfresh's Avatar
    Jul 2010
    Connecticut
    If it was properly installed and torqued to spec than the only thing that could have shaken it loose is an imbalanced rotating assembly in the motor.
    As a precaution, check your serpentine belt pulley and timing belt crankshaft pulley for proper torque as you are putting this all back together.
    Who installed the flywheel and clutch?
    -Doug
    2002 A4 2008cc GT-3076R turbocharged Avant
    397awhp/371awtq on straight 93oct and 96*F ambient
    tuned by Autospeed Performance
    I installed the clutch and flywheel myself. I know for a fact I did everything right. Ill check the crank pulley torque when I'm reinstalling everything. But they only thing that is confusing me is that the timing belt tensioner is loose. I don't know how either its onlyt got 6k miles on it
    I torqued everything properly and used red loc tite
    euro addict DaveD is a well respected and helpful member of Euro Addiction DaveD is a well respected and helpful member of Euro Addiction DaveD is a well respected and helpful member of Euro Addiction DaveD is a well respected and helpful member of Euro Addiction DaveD's Avatar
    Looking forward to a good outcome for you
    Previous rides:
    E60 M5 - Lotus Elise - E90 335i - B6 S4 Cab - E46 ///M3 - 2005 PES Stage 2 S4
    2004 Nogaro S4 - 2000 S4 Stage II - 2007 A4 2.0T K04 - 2004 A4 1.8T USP
    Royal Flush Rallies
    N.E.R.D
    Arnold Palmer Club Member #3
    Quote Originally Posted by DaveD View Post
    thanks dave, i appreciate it.
    ill be ordering up a bunch of maintenance stuff will be alot easier installing all the vacuum lines while the motor is out. there might be a new turbo kit coming too a lil t28 set up we will see
    well the motor went back in on tuesday. my new tensioner and vacuum lines will be here tom. my new apr snub mount and 034 motorsports trans mounts will be here either saturday or early next week. im hoping to have the car running tom. but if not saturday night. hopefully no problems show up
Tags for this Thread
