I'm really excited that I had to start a post of my build. There's a lot of things I want to do with my A4.
1- Build a Stroker Engine
2 - Wideband Conversion - AEB to AWM
3 - Car face lift
Stroker Build -
So far what I have for my build
ABA Forged Crank
82.5 Supertech Pistons
IE Rods - I-Beam
Precision 6057 Turbo
PAG Logger Manifold
3in Downpipe
3" Custom Exhaust - (Doing some changes)
38mm MVS Tial External Wastegate
ATP Fuel Rail
Fuel Pressure Gauge
044 Fuel Pump
Tial 50mm BOV
R32 Throttle Body
044 Fuel Pump
ARP Head Studs Kit 058
ARP Main Studs 058
ARP Crank Bolt
Crank Rear Seal
Crank Gear Pulley
ARP Fly Wheel Bolts
Head Gasket set-(Big bore head gasket)
Main Bearing Caps Billet
Main Bearings w/Thrust Washer Set
Rod Bearings +.001" ACL calico coated
Fluidampr Harmonic Dampner
Turbo Cover
1000cc Fuel Injectors
Eurodyne Software
Supertech Valves
Cat Cam Springs
Titanium Retainers
Purple Cat Cams
Lifters
Timing Belt Kit
All Mounts
FX400 Clutch
Light Weight Steel Flywheel
Cat Cam Gear
TR1035 - Treadstone FMIC with 2 1/2 custom piping
I'm sure I have more thing that I need to buy.
For the wideband conversion I bought all the wiring harness from a 01 AWM A4 - Once I start working on this I'll post more information on how everything goes with the conversion.
Face lift -
I painted my RS4 bumper
Want to change the lower part of the rear bumper
Want to change the sideskits
I'm also painting my Boser
Changing rear shocks
Changing to S4 brakes (front and rear)
Here's pics of my car before I put my car in the garage
While I was waiting for my block and cylinder head come back from the shop, with my friend we took out the engine and installed it on my other A4.
Here's how my conversion is going... Lol
Here are some pics of the parts I bought
IE I-Beam Rods
Presicion 6057
I got my block at the machine shop and I'm gonna get a heater in the garage so I can continue working.
Thanks for checking out my build!![]()
2003 Volkswagen Jetta
Austin
2008 Audi RS4
2007 Audi S4
2001 Audi A4
2000 Audi A4 1.8t
