Just released from 034Motorsport:
034Motorsport Adjustable Front Upper Control Arm Kit C5/B5/B6/B7 chassis
Intro Pricing = $495 plus shipping(retail = $525)
PRODUCT SOLD HERE (http://www.jhmotorsports.com/shop/ca...roducts_id=640)
This adjustable front upper control arm kit is made by 034 Motorsport. These are direct replacement arms for the stock front upper control arms on the C5 A6, B5/B6/B7, A4, S4 and RS4. These arms add adjustability to fine tune camber and caster settings on these vehicles. These arms also use heavy duty bushings to retain maximum road comfort and eliminate noise and harshness while being more durable than stock.
The custom outer rod end style ball joints feature Teflon linings and are sealed to provide years of maintenance free operation. Since the rubber inner bushings are replaceable these are the last arms you'll ever need!
Also if you are tired of wearing out the front inner edge of your tires ever since you lowered your car, these arms are the solution for you! When you lower your car it adds excessive negative camber causing this problem and the factory arms are non adjustable to fix this. With these 034 arms you will now be able to adjust camber within OEM specs for better tread life.
FEATURES:
Provides adjustable camber/caster
Retains factory ride comfort
Quick installation
Black anodized finish
FITMENT:
1996-08 Audi A4 All
2000-08 Audi S4 All
1998-04 Audi A6, Allroad All
2007-08 Audi RS4 All
1998-05 VW Passat All
Note: First 15 orders in and paid will ship by end of next week. All other orders will ship in 2 to 3 weeks.
