Hey Guys - sorry for the bummer first thread. I figured if anyone can help its the crew from
I was driving along the other day and my car (2005 B6 S4 64k miles) suddenly started shaking. Lots of driveline vibration. The CEL came on and started flashing. It seemed real bad. It seemed to be rougher at lower RPM (idle). It appeared to get smoother as it reved slightly higher (2k - 2.5K). I didn't take it any higher for fear of massive explosions. Subsequently the car takes about fifteen seconds to start. I've never noticed any rattle at startup, but I suppose it could be there and i just don't know what to listen for. The car has 64k miles, I've had it for the last 22k of which I've had only minor issues (starter, replaced MAF sensor). I've done oil changes every 5k, before that they were done at 5,15,24,32,and 38. Like I said I didn't notice any symptoms of an issue prior to this happening. This happened in the middle of a fifteen minute drive across town at about 20mph. It happened as I shifted from 1st to second at about 2.5k. Also my low fuel light came on about five minutes earlier, but i suspect that's unrelated.
I got it to a local shop where they looked at it today. The tech says he's pretty sure its a busted timing chain tensioner. He said he got zero compression on cylinder 8. He did have a spark on the plug. He read codes but i don't have them. He said the next step would be to remove the valve cover form one side and see if everything (valves) lines up properly. He roughly estimated worse case 45 hours to do the whole job plus 2-3k for parts depending on what he finds. He's done fine work for me before on my front brakes and new starter, but I'm not confident he can handle the engine pull and timing work.
I decided to have it towed to an audi dealer in the next town over. They will start looking at it tomorrow. I'm hoping they have another theory.
I'd like to pretend I understand everything that's going on and what I've read. But honestly its a bit overwhelming. I don't have alot of details at this point, but I'll update this thread as I find out more.
UPDATE#1 posted below. 1/12/2011
UPDATE#2 tech's notes posted below. 1/18/2011
UPDATE#3 short videos posted below. 1/25/2011
-This is not intended to raise fear about everyone's car randomly imploding. My appologies.
smurfette
2004 Audi S4
Austin
Oh-One Aye-Six Fat-Body Four-Two
2002 Nissan Xterra
2004 Audi S4
Vorschlaghammer (B7 S4)
Dark Angel
Red
