Results 1 to 10 of 10
Thread: Dyno Test Results
    EA Member melloyellows4 has an average reputation melloyellows4's Avatar
    Default Dyno Test Results
    I thought i would share the results of my dyno test on a Mustang dynamometer. The car is a stock 2005.5 B7 S4 with LW pulley. I will be installing FI dps and catback exhaust next week and will re-dyno. Ultimately, I will get JHM tune and get a final dyno.
    Pull 1: max torque = 229 ft.lbs max HP = 237
    Pull 2: max torque = 242 ft.lbs max HP = 245
    Pull 3: max torque = 244 ft.lbs max HP = 247
    EA Member Jnaut has an average reputation Jnaut's Avatar
    Jan 2012
    Congrats on getting your car on the rollers. Mustang dyno's are not forgiving as typically they read much lower than dynojets. Was your car being tuned at the time? Do you have a sheet to post?
    EA Member btek has an average reputation btek's Avatar
    Northridge CA
    that's close to what I've seen a stock car do on a mustang dyno.
    btek
    08 S4 Avant 6M, RS4 grille. stock
    Enthusiast vweater1369 has an average reputation vweater1369's Avatar
    Fresh 2 Death
    Can you scan up the dyno charts?? I'm curious to see what they look at.
    As I have no idea what S4's are supposed to make, I can't comment on the numbers lol
    Is the car a 6MT or a TIP? Where did you have the pulls done?
    Agreed, Mustang dyno's are one of the lowest reading dyno's out there
    The car is 6MT and the pulls were done at ECS Performance in Connecticut. I have a PDF file for pulls so can someone tell me whats the best way to post them.
    Thanks
    Enthusiast Vee8s4 has an average reputation Vee8s4's Avatar
    Save them as a JPEG and then upload them to photobucket or some other host.
    Those numbers dont seem too bad at all. Most stock 6MT cars are putting down around 260whp. Mustang dynos read a little low.
    2004 S4 - Moro Blue 6MT.
    Apikol snub & diff mounts / 2.5" custom cat back w/ X-pipe / piggies / JHM tuned
    Enthusiast Mr.Corey has an average reputation Mr.Corey's Avatar
    NYC
    Quote Originally Posted by Joey View Post
    You dyno'd your S4 on a Mustang right Joey...?
    B6 Nogaro S4 Alcantara 6MT with some mods
    Website www.coreymaywalt.com
    Quote Originally Posted by Mr.Corey View Post
    I think that is what it was. Was about 2 years ago now so i don't quite remember.
    EA Member notdisturbed has an average reputation notdisturbed's Avatar
    Quote Originally Posted by melloyellows4 View Post
    I ran my car on the ECS dyno in 2009. With only a cat-back i put down 265hp/261tq.
    2005 Nogaro Blue S4 6MT - JHM Tune, Piggies, FI 8" Res Cat-Back, Cayenne calipers w/JHM rotors & HPS pads, V708's w/RE01R, E-codes and HID fogs
    2004 Mini Cooper S(wife's car) - Remus Cat-Back, Alta 19% pulley, S&B Intake, Alta Intercooler w/spray, Custom Tune
