I bought a 2005 S4 about a month ago. No service lights on when I got the car. Pulled nicely. Had some vibration in the seat.
It ran fine until I just changed the serp belt and snub mount along with valve cover gasket kits, plugs and coils.
The car is acting like it is limp home mode (had a Benz that did this, but not sure if the Audi does the same thing)
It is now throwing the following codes:
16486 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 002 - Lower Limit Exceeded - MIL ON
17800 - Camshaft Position Sensor Bank 2 (G163): Open Short to Plus
P1392 - 001 - Upper Limit Exceeded - MIL ON
17746 - Camshaft Position Sensor (G40): Open or Short to Plus
P1338 - 001 - Upper Limit Exceeded - MIL ON
18041 - Accelerator Position Sensor 2 (G185): Signal too Low
P1633 - 002 - Lower Limit Exceeded - MIL ON
Before doing the above the only engine code was the following:
18613 - Performance Malfunction in Cooling System
P2181 - 008 - Implausible Signal - MIL ON
I think this was a result of one of the first few days I had the car where the temp guage was not reading. I bought a coolant temp sensor as a potential fix.
Prior to this, I did the following:
Oil/filter change
Cabin filter change
Cleaned and oiled existing K&N air filter (wondering if this messed up the MAF and is resulting in other codes as I've read the K&N oil messes up the MAF)
Items left on my list:
PCV valve
Fuel filter
Figure out where vibration is coming from. Seems to be there when car is not moving so it may be misfiring or something.
Any help and/or suggestions appreciated.
Eric
The Green Goblin
