Results 1 to 5 of 5
Thread: Audi B6/B7 S4/A4 DIY: Service Indicator Reset
    euro addict DaveD is a well respected and helpful member of Euro Addiction DaveD is a well respected and helpful member of Euro Addiction DaveD is a well respected and helpful member of Euro Addiction DaveD is a well respected and helpful member of Euro Addiction DaveD's Avatar
    Default Audi B6/B7 S4/A4 DIY: Service Indicator Reset
    I know this is a very simple one, but always good to have. After your done with your oil change and other regular maintenance you will need to reset your service indicator, this can be done with vag-com, but some of you like me don't have one yet. Here is how to reset it without using a vag-com:
    1. Put key to the off position
    2. Push down the wrench button
    3. Turn key on while still holding the wrench button, but don't turn on the car
    4. While still holding the wrench, push 0.0 next to the wrench
    Your service is reset!
    And with VAG-COM:
    Audi has included a Service Interval Reminder that includes oil mileage interval, the service mileage interval, and the service time interval. To reset the Service Reminders using VAG-COM:
    Using the current version of VAG-COM, simply go into Applications then click on SRI Reset. VAG-COM will automatically interrogate the cluster to determine what if any reset parameters are available. Click this link for more information.
    If you are using an older version of VAG-COM then you should follow these instructions:
    1998 and Newer:
    [Select]
    [17 - Instruments]
    [Adaptation - 10]
    Enter channel 02
    [Read]
    The "Stored Value" is the current value for that channel.
    Enter the "New" value of 0 (zero)
    [Test]
    [Save]
    Note: It is normal for the display to show something like "--/--" instead of an actual distance/time to service after resetting until you have driven some distance.
    Pre-1998 models ... or if Channel 02 is not available:
    [Select]
    [17 - Instruments]
    [Adaptation - 10]
    Enter the correct channel from the list below in "Channel Number"
    [Read]
    Enter the "New" value of from the list below.
    [Test]
    [Save]
    Channel 05 should be the distance until the next Oil Service.
    It is in thousands of kilometers. Let's say you want the Oil
    Service light to come on in 5000 miles. That would be 8000 km.
    Put the value 8 into channel 05. The "standard value" used by the US
    dealers would be 12 (7500 miles).
    Channel 06 should be the distance until the next In-1 Service.
    Same units as above. Standard value would be 24 (15,000 miles).
    Channel 07 should be the time until the next In-1. In-1 lights
    up based on time or distance, whichever comes first. This is in
    10's of days. Standard value would be 36 for 360 days.
    Channel 08 would be time until the next In-2. In-2 is based
    strictly on time. Standard value is 72 for 720 days (about
    two years).
    Previous rides:
    E53 X5 6 speed - E36 M3 - E350 Coupe - E63 M6 - E46 ZHP - E60 M5 - E46 M3 Vert
    E90 335i - E30 Mtech1 S50 -2005 Nogaro S4 - Lotus Elise - E90 335i - B6 S4 Cab - E46 ///M3
    2005 PES S/C S4 - 2004 Nogaro S4 - 2000 S4 Stage II - 2007 A4 2.0T K04 - 2004 A4 1.8T USP
    Royal Flush Rallies
    N.E.R.D
    Arnold Palmer Club Member #3
    Enthusiast PNW Avant has an average reputation PNW Avant's Avatar
    Seattle, Wa
    Thanks!
    2005 Brilliant Black A4 Avant 1.8TQM Sport Pkg
    2004 Arctic White S4 Avant 6MT -Sold-
    Moderator
    Charlescrs6 is on their way to something great Charlescrs6 is on their way to something great Charlescrs6 is on their way to something great Charlescrs6's Avatar
    Darien, CT/ Bristol, RI
    Maybe easy but I had no idea how to do it lol. Thanks Dave, just did it!
    New Member alaskawiner has an average reputation alaskawiner's Avatar
    Dec 2012
    thank you
    EA Member 0396 has an average reputation 0396's Avatar
    As usual- A Big Thank You for the step by step instructions
