Page 1 of 5 1 2 3 ... LastLast
Results 1 to 40 of 166
Thread: 1.8l + PTE5857 = 425awhp?
    Enthusiast Dan[FN]5857 has an average reputation Dan[FN]5857's Avatar
    South Central PA
    Default 1.8l + PTE5857 = 425awhp?
    So there I was, running a GT71R with terrible IAT issues. So what did I do? Pull my engine and do a PTE 5857 build. It was the only logical choice that I had.
    I'm bored at work, so I figured that I would start my build thread.
    I have some really crappy pics that I took with my crappy cell phone (I know, double fail) and so I only have terrible pics to show you as of now. I'll take better ones later.
    As far as the build goes, I want to keep it pretty basic.
    -Engine
    - IE rods w/ stock pistons new rings and rod bearings
    - A refreshing hone for the block
    - Port and polish AMB head
    - AEB intake mani
    - Exhaust valves
    - Supertech valve springs w/ titanium retainers
    - Stock cams (as of right now)
    -Tuning/Fueling
    - Probably Unitronic or Maestro... I want to run 1000cc injectors, so whoever can give me tuning for it
    - 005 intank pump
    - stock fuel lines w/ "returnless" system
    -Cooling
    - Treadstone TR10 w/ custom 2.5" piping
    - Possibly W/M
    -Turbo Stuff
    - PTE HP5857SP (running like, 1 million PSI)
    - Hoping the Treadstone manifold will fit, otherwise idk
    - Tial wastegate
    - Hallman MBC
    -Exhaust
    - Custom 3" downpipe w/ wastegate routed into it
    - downpipe -> 24" cherry bomb 3" in/out to 2.5" Y to 2.5" out the back
    I'm sure that I'm forgetting something....
    OH YEAH!!!
    -Clutch
    - Something big and ugly from CM. I'll need to talk to Greg@DTH. I was thinking something like the FX850
    Thanks to Clay@CTS for the Turbo and Clint@RAI for the awesome deal on the bottom end parts!
    whoops, also forgot the add the pics.
    -Dan
    PTE HP5857SP build completed.
    EA Member Rubadubdub has an average reputation Rubadubdub's Avatar
    Westchester, NY
    Every thing looks great good luck with the build. Just one question.. Why dont you pick up an AEB head? They can be had for 300 naked and you just have to swap over the parts. Im sure it will be cheaper and easier that way
    -Erik
    .gif Bomber
    justin is a well respected and helpful member of Euro Addiction justin is a well respected and helpful member of Euro Addiction justin is a well respected and helpful member of Euro Addiction justin is a well respected and helpful member of Euro Addiction justin's Avatar
    I second the idea of a AEB head. In any case this is going to be an awesome/fun build can't wait to see how it turns out! Oh and nice tags btw LOL.
    South Central PA
    i was going to do an AEB head, but everyone does that. and i can port and polish it myself, so there wouldnt be any extra cost as far as that goes.
    im more interested in what the 1.8l with stock cams can do. i think it would be good info seeing as how everyone always does 2.0/AEB/Cams.
    -Dan
    EA Member audi2ptzero has an average reputation audi2ptzero's Avatar
    Socal
    The CM 240mm FX400 6 puck would be plenty, it will hold around 700 ft lbs of tq and uses a clutch that the S4 2.7t stage 3 guys run.
    $600 difference between the 240mm FX400 package and the FX850.
    The stock cams are going to be the biggest factor on how much power you end up making.
    South Central PA
    Quote Originally Posted by audi2ptzero View Post
    Thats really good info about the clutches, thanks! that helps a lot with my decision.
    yeah, cams are easy to swap out tho, im just curious what it'll make with the stockers
    -Dan
    Socal
    If you have the time then seeing how much you can make with the stockers before going to a larger cam is a good idea. Then you can also do the same with the small port head vs a AEB head.
    South Central PA
    thats the plan
    -Dan
    South Central PA
    block is honed. sorry for the crappy pic, I forgot my camera again.
    -Dan
    Enthusiast AudiA4_20T has an average reputation AudiA4_20T's Avatar
    I could hardly tell what was going on with my POS phone lol
    Broken '04 S4. 2.7T swap until I build the 4.2
    South Central PA
    Quote Originally Posted by AudiA4_20T View Post
    hahahaha!!!
    -Dan
    Westchester, NY
    Quote Originally Posted by Dan[FN]5857 View Post
    Everyone does it cause it the best bang for your buck. Honestly if you cant flow test it after your done dont to it. Why allow for a chamber to flow less air then the others? Or even worse they all flow way different numbers. the AEB head is a strong starting piont as well as something that needs no work after (ex: port and polish). not only will you then have a huge paper weight but you would have to go buy a AEB after, aleast with the stock head you can resale it and make up some money.
    cams are to much of a gamble with 1.8t. i heard really bad stories from both shops and private builds.
    your best bet is a stripped AEB head and do larger valves and Heavy duty springs, Youll have great flow through the head and it will allow you rev a bit more, increasing your power band.
    -Erik
    South Central PA
    Quote Originally Posted by Rubadubdub View Post
    I understand your point entirely, trust me, I really do. I am doing exhaust valves and heavy duty springs w/ titanium retainers, so it should be good for a soild 8k rpm. I was basically going to port match the AEB mani that I have so that it is as fluid of a transition as possible.
    -Dan
    Westchester, NY
    Your going to love the valves and and springs. I had them installed in my R32. (know its completely different) while normal a turbo R spools at 3400 and make full boost at 4200, i spool at 2200 and make full boost just before 3000. People dont understand how that possible, but with the right parts and my boost controller i have no lag and pull to 8k like a freight train.
    -Erik
    What turbo? I'm so jealous. We're doing an A3 3.2 with a 35R at the shop right now, thing is gonna be awesome
    Westchester, NY
    gt35r 1.06 a/r, im really upset with my gt35 to be honest their are a shit load of new turbos out that the are not only cheaper then the 35r but spool quicker and hit harder.
    ANd have cheaper Center housings so when you blow the seals like i did on mine after the warrenty is up your not shelling out 500+ for a new center housing. more like 250-400.
    -Erik
    Funny that you say this, I have been looking around at turbos lately. To be honest, the 35R is an awesome turbo though. I think the 1.06A/R is whats making you mad about the lag and stuff. I DO agree with the rebuild cost though, that can DEFINITELY get old.
    I would check out the HTA, I did it on mine and its faster for sure.
    South Central PA
    I can't wait to find out how mine spools
    -Dan
    Euro Addiction Advertiser Mike@Ringer-Racing.com has an average reputation Mike@Ringer-Racing.com's Avatar
    Clint when are you not looking at new turbos? lol
    The 1.06 is going to a bit more laggy but he is most likely running that big of an A/R because its on a VR6. I am still waiting to switch to a HTA3586r but cant really complain seeing that I even my damaged exhaust wheel GT35r made 570whp on 110 octane only pushing 32psi and ran 10.55. My good GT35r made a little more then that pushing 37psi but it did hit a little sooner.
    Westchester, NY
    I dont have lag problems. lol
    -Erik
    How is it possible for a 3.2 liter with a GT35r spool at 3400 and make full bost at 4200? Even I do that on just 2.0 liters with a .82 a/r GT35r. They should all be spooling before 3k rpms since a GT35r is a pretty small turbo for 3.2 liters of displacement.
    Westchester, NY
    Quote Originally Posted by Mike@Ringer-Racing.com View Post
    no idea.... i feel like i spool at idel.
    -Erik
  23. #23
    South Central PA
    lol I wanna ride in your car. Do you have any dyno charts?
    -Dan
  24. #24
    Westchester, NY
    I should have a chart posted by next week it will be retuned on the dyno, once Garrett decides to send me my Center housing. A two day turn around has turned into a week and a half.
    -Erik
  25. #25
    South Central PA
    bottom end is assembled. sorry for the shitty pics, I didn't feel like walking out to my truck to get the camera. I promise I'll take better ones lol
    -Dan
  26. #26
    South Central PA
    were you able to get your car dyno'ed yet?
    -Dan
  27. #27
    South Central PA
    finally got the head put back together. had a bitch of a time with the keepers lol
    -Dan
  28. #28
    Euro Addict 1redavant has an above average reputation 1redavant's Avatar
    Warwick
    Keep us posted!
    Driving:
    2006 Brilliant Red A4 Avant 2.0TQM
    Revo Stage 2|Carbonio Intake|Stasis SS coils|Podi Gauge|RS6 OEM 18"|H&R spacers|RS4 F/R sways
    custom inlet pipe|Milltek turbo back
    Arnold Palmer Club Member Agent 0
    Contact me for all your decal and graphic needs Infinite Graphics
    Endorsing: -N.E.R.D. -Royal Flush Rallies -EUROaddiction -Arnold Palmer
  29. #29
    South Central PA
    lol im trying! if there is a god, he will give me the ability to have to car 98% ready to run by the end of the day sunday.
    -Dan
  30. #30
    South Central PA
    the camera on my phone fucking sucks. i forgot the digital again []
    -Dan
  31. #31
    That clutch is looking pretty good on that engine. I might have another A4 owner that is lookign to run that clutch too on his built 2 litter with a GT3076r.
    Just leave the camera with the car, you will need to take more pics anyway.
  32. #32
    South Central PA
    oh yeah, i love how the clutch looks lol. nice. i can't wait to find out how it feels.
    yeah, leaving the camera with the car is good idea actually lol.
    hopefully tonight i can have it 98% ready to go.
    i still need to get IC piping, TIP, and a Downpipe. i have everything else. to start it up and break it in.
    goal is to have it finished for waterfest.
    -Dan
  33. #33
    South Central PA
    this clutch feels awesome. i havent got to run it yet, but i love how the pedal feels.
    -Dan
  34. #34
    Good to hear and I feel exactly the same way. The 850 pretty much has the perfect "performance" pedal feel, not soft but yet not too stiff. One of the big reasons I kept bugging CM to make a single disk 850 setup.
  35. #35
    South Central PA
    yeah, man, it was definitely worth it. its perfect.
    -Dan
  36. #36
    Moderator dougyfresh has an average reputation dougyfresh's Avatar
    Jul 2010
    Connecticut
    update this thread, Dan. You have pictures to show us.
    I want to see that IC pipe that someone did a really good job fabbing up
    -Doug
    2002 A4 2008cc GT-3076R turbocharged Avant
    397awhp/371awtq on straight 93oct and 96*F ambient
    tuned by Autospeed Performance
  37. #37
    South Central PA
    lmao sorry, I always forget that I started this thread on here also.
    I'll see what I can do.
    and that IC pipe is money.
    -Dan
  38. #38
    South Central PA
    got the bumper cover to fit tonight. with the help of my irreplaceable buddy glen lol.
    Had to take a little bit out of the bumper cover. (i dont want to hear it Doug lol)
    -Dan
  39. #39
    Is there a bottom valance for that bumper that will give you more room for the FMIC?
  40. #40
    South Central PA
    do you mean like a USP lower half?
    after I get this running 100% and retuned, I'm going to start looking at some different from bumpers. I would like something that is OEM like a USP or S4 bumper. I want it to look as OEM as possible. I'm not big on aftermarket bumpers.
    -Dan
Tags for this Thread
