So recently (the other day) I changed up the TURBO SETUP on my Avant
I know i posted i wanted to sell her off, was/have been frustrated with the Avant for some time. But i had a deal presented to me so i went for the deal/option and well now i need to do some testing for PSi CONCEPTS.
So here is what i went with:
PSi Concepts CONCEPT Series TD05H-20G
PSi Concepts T-25 Flanged Manifold (already had)
PSi Concepts T-25 Flanged Down Pipe (already had)
Psi Concepts Oil/Coolant line kit (aready had)
Tial 38mm waste gate (already had)
NEUSPEED Extreme TIP (already had when i went REVO2)
Race Tech FMIC (already had)
Forge Splitter DV (needs to go i want Forge 007) hint!
Forge MBC (set at 20psi for now)
REVO 550 cc BT File w/ 630cc injectors
Some motor work (already done)
Some pics of turbo:
So now for the install:
We removed the old setup. GT28rs (for sale) hint
In order to ge the 28rs out we took off we had to remove/loosen the motor mount and bracket. THen we pushed the motor up a little allowing for more room.
With everything out of the way it was easier to get to the turbo studs. We were gonna remove the Manifold as well but actually managed to ge the turbo out with out removing that.
Ok so for install pics:
with everthing out of the way and the new turbo being a V-Band setup we were able to get the hot side in after welding the Waste Gate shut.
Jeff@PSi wanted me to run same setup i had on the 28rs. Thats why the waste gate is welded shut.
hot side, nice and tight with some locking nuts
Now to test fit the Cold side. We had to make sure the turbo was clocked right and that it matches up to the intercooler pipes ( i wasnt changing a thing)
NOTE: how the Oil line is sitting.......needs to be changed. Didnt have all the parts that came with the PSi Oil/Coolant line kit. (at another shop).
So now that everthing was lining up we had to bolt all the rest of the stuff removed back on.
This turbo utilizes a smaller inlet than your standard GT28rs, by that you are able to use your NEUSPEED,APR, 034 TIP's. No need for a custom TIP.
* But * Jeff@PSi does stress that this turbo run with a 3"MAF
And yesss a 3"MAF does fit in a in a NEUSPEED TIP!
- I need to do some more logging and adjust my Revo settings.
Stay tuned for more info!
Hopefully this can work out to be an afforable BT for everyone!
More details to come as i test the new setup!
The Project... thats never ending
2001 Audi A4
The Green Goblin
