Results 1 to 7 of 7
Thread: Help me troubleshoot dad's B6 1.8t
    Moderator MrMThree has an average reputation MrMThree's Avatar
    Fairfield, NJ
    Default Help me troubleshoot dad's B6 1.8t
    Ok so all of a sudden dad's car just would not hold idle.
    had a random misfire code, and a misfire code for each of 4 cylinders as well as a lean condition code.
    While doing a tune up on the car (plugs, air cabin fuel filters, oil) i replaced a broken check valve which took care of the vac leak. i thought thats why the car wouldnt hold idle, i was wrong.
    so, here's what i have so far
    -the car gets fuel, the plugs are covered in gas.
    -car doesnt hold idle at all. have to keep revs over 2k. while doing so theres a loud pop from the back of the motor every 4 or 5 secs. like a backfire (knock sensors have anything to do here)
    -since replacing the check valve i'm half a can of starter fluid into searching for other vac leaks and theres nothing.
    -oil looks and smells fine on cap and dipstick
    -coolant take/cooling sys was pressurized. after 3 or 4 days sitting i took the cap off and coolant burst out
    no sign of oil in the coolant
    -i'm going crazy
    -sections of hair missing on my head from me pulling it out.
    where do we go from here? coil packs? it just all of a sudden crapped the bed, it makes little sense we'd lose all 4 coil packs instantly at once.
    anybody?
    not much of a diag. tech, esp not with audis!
    TIA,
    Mike
    -Mike
    98328is-track whip to be
    99 Silver/Black M3-soon to be for sale
    98 Estoril/Dove M3/4/5 -Sold
    96 Dakar/Black M3-Sold
    coilpacks are a good bet, do you have the ability to scan codes? If its misfiring and you move the coilpack and the misfire moves with it, then there's the issue.
    Fairfield, NJ
    yea, as mentioned, misfire code for each cylinder
    joey informed me about the recall being done right now, so prob just going to bring it to the dealer and crosss my fingers
    -Mike
    .gif Bomber
    justin is a well respected and helpful member of Euro Addiction justin is a well respected and helpful member of Euro Addiction justin is a well respected and helpful member of Euro Addiction justin is a well respected and helpful member of Euro Addiction justin's Avatar
    Willing to put all my money on the Coil Packs. Mike I got a few spares we can swap in to see if thats the issue just give me a shout on my cell.
    Euro Addiction Advertiser Sam@elitemotors has an average reputation Sam@elitemotors's Avatar
    check your coil pack harness for cracking for damage in the wiring, also if you really want to find a vac leak the best way would be to run a smoke test on the motor. If your still stumped and would like us to take a look at it, please let me know...
    We understand your obsession....
    http://www.elitemotorsnj.com
    elitemotors@gmail.com
    201-820-3800
    Fairfield, NJ
    joey told me they're doing a recall on coil packs. giong to bring it by the dealer and see if they'll do it, if not, sam and justin you guys will both be hearing from me
    -Mike
    Passionate a4spoolin has an average reputation a4spoolin's Avatar
    hardyston,new jersey
    Sounds like you got a leak still. Run a boost leak test, its very easy. How many miles on the car? Those check valves and vacuum lines get extremely brittle.
