Results 1 to 16 of 16
Thread: My RS4 on Meth plans :P
    Enthusiast Retsujou has an average reputation Retsujou's Avatar
    Default My RS4 on Meth plans :P
    So after being sucked into this whole idea by you people I researched around a little bit. I talked to dan@labontemotorsports and he advised me of their S3 system which you can look at here.
    http://www.labontemotorsports.com/st...ow/ISG-S3.html
    That system does not run off the MAF it actually picks up RPM+IDC+Vacuum even for the FSI engines. They are running the S3 kits on the Audi R8 V10 and the recent corvettes with some rather good feedback. Their S4 system will be out end of June, first boost activated the other version following shortly after.
    I am thinking that I will put the pump either in the wheel well on the front or I will actually have the pump and the tank in the back, balancing the extra weight added by removing the heavy OEM battery. I know that running the lines would be a nightmare, however it is all a matter of having enough room up front.
    He says that running a single M4 nozzle is most likely enough. The ECU should be able to adapt to the system automatically. I do not thin an extra tune is needed. We shall see how it goes, once the system is released I will speak to VAST and see whether they are willing to install it. What I really like about this system is that it is actually capable of reading the Injector Duty Cycle on the FSI engines.
    I shall keep you posted.
    08 B7 Cherry Black Pearl RS4 + JHM Lightweight Flywheel + JHM Stage III Clutch + VAST Piggie Pipes + K&N High Flow Airfilter + APR Stage II (Testpipe tune) + Hueper Optik 30% + Magnaflow X-Pipe + Centre Resonator Delete + Deflap + HAWK Ceramic front/rear + Stoptech Steel Brake lines + Potenza RE-11 275/30-R19 (on stock rims for now)
    euro addict DaveD is a well respected and helpful member of Euro Addiction DaveD is a well respected and helpful member of Euro Addiction DaveD is a well respected and helpful member of Euro Addiction DaveD is a well respected and helpful member of Euro Addiction DaveD's Avatar
    Looking forward to seeing your results!
    Previous rides:
    E60 M5 - Lotus Elise - E90 335i - B6 S4 Cab - E46 ///M3 - 2005 PES Stage 2 S4
    2004 Nogaro S4 - 2000 S4 Stage II - 2007 A4 2.0T K04 - 2004 A4 1.8T USP
    Royal Flush Rallies
    N.E.R.D
    Arnold Palmer Club Member #3
    IMOLA - THE FASTEST COLOR boravr6 is on their way to something great boravr6 is on their way to something great boravr6 is on their way to something great boravr6's Avatar
    Barrie
    so any reason why a meth application could not help out keeping the IM cooler the S4?
    Or are all RS4 just getting that to reduce carbon buildup?
    ** Proud to support **
    JHMotorsports
    www.audirevolution.net
    ~ 2006 Imola B7 S4 sedan 6MT
    ~ 2004 Silver B6 S4 sedan 6MT *SOLD*
    Arnold Palmer Club Member #8
    Follow Nobody RS4POWER has an average reputation RS4POWER's Avatar
    What happened to the APR S/C?
    Interesting, I'm curious as to how this will all work out.
    Passionate NY07RS4 is on their way to something great NY07RS4 is on their way to something great NY07RS4 is on their way to something great NY07RS4's Avatar
    I had thought a tune WAS necessary to take advantage (or full advantage) of a w/m system...? I know PES has the I/M with the bungs for each cylinder, I wonder if there is an advantage spraying with 8 nozzles there vs. the single nozzle elsewhere. I would think the 8 nozzle route would help more with the CB issues on the back of the valves since it would be a more direct route with almost instant contact. Nonetheless, interested to find out your feelings and results once installed.
    Quote Originally Posted by NY07RS4 View Post
    The tune will make better use of the W/M. Without the tune, the ECU should adapt to the cooler intake charge by using more timing advance. With a tune you can start to compensate more aggressively for the cooler charge and higher octane rating of methanol.
    i can has forced air pls? Living Weapon has an average reputation Living Weapon's Avatar
    Taxachusetts
    It may be worth graphing volumetric efficiency from logs as shown here, to see if wet flow in the manifold costs us any air capacity.
    This was a constant debate at the import forums, that manifolds and intake ports designed for carburetor setups (wet flow) were somehow optimized differently than direct injection motors (dry intake). The theory was that where flow changes velocity (bends in runners, or at the valves) the difference in weight of one cubic foot of air vs. that same air volume with fuel or water droplets suspended in it would impact VE.
    If all it takes is some logging and spreadsheet work to settle this debate once and for all, I'd love to do some driving with vs. without meth once I have my car back from the clutch and suspension install.
    Let me correct something I said. The tune is not necessary to get the benefit of cooler intake temperatures and thus the ECU starting to pull timing. If you wanted to have more aggressive timing to begin with because you are compensating for the Meth/water mixture then the initial maps would have to be adjusted of course. That is not really what I am looking for at the moment, as I am sure JHM will come upw ith something or APR might.
    As to the Super Charger. I am still on the list, but I have heard nothing from APR for a month so I am beginning to make other plans for my money. I am trending towards saving the cash and putting it into a different car, one the ones mentioned here. I will have a chat with sharkwerks about that later this week.
    Quote Originally Posted by Living Weapon View Post
    I think we should truly instal a web-service somewhere , where people can submit their logs and all kinds of data will automatically be mined.
    Euro Addict mbgt72 is a well respected and helpful member of Euro Addiction mbgt72 is a well respected and helpful member of Euro Addiction mbgt72 is a well respected and helpful member of Euro Addiction mbgt72 is a well respected and helpful member of Euro Addiction mbgt72 is a well respected and helpful member of Euro Addiction mbgt72's Avatar
    Nashville, TN
    Quote Originally Posted by Retsujou View Post
    I too was looking at the kits that they had, however, I was actually looking at the one that ran off of the MAF. All the others mentioned using boost to control spray volume nad I figured the MAF would be the easiest and cleanest install. I'm not too experienced in meth so please school me as this is an install I'd be tackling myself.
    On another note I talked to jhm and they said that the tune should both account for the cooler temps and richer octane and adjust accordingly, so correct, an additional tune would not be needed.
    Finally if I do go this route ( and I do want to do this, if nothing else to help keep the internals super clean and be ready for a sick s/c application) I had thought the best setup would be move the battery to the trunk, particularly the side compartment like ngng did, and then put a smaller meth/water tank in the original battery location. You may have to fill it up a little more often but to me it seems like the easiest and best option.
    so lets hear your thoughts and school me on my errors!
    2005.5 MT6 S4 l JHM: Stg 1 Supercharger, SS Trio, Snub, LW Pulley, LW Front Rotors ,LWFW, Stg IV clutch, 4:1 Diff, Rear Diff Mount, Trans Mount, Stern Motor Mounts, IM w/ Spacers, 93 Tune, 2.5" Catless Milltek Dp's and Fast Intentions Res B6 Cat-Back l H&R C.O. 24.75" G-F, 034 Adj UCA's, H-Sport RS4 Rear Sway l Hawk HPS Pads, SS lines & SuperBlue l DDM 5000k H.I.D Fogs, Fly'sV4 LED, LED City & DRL, CC l 15% Tint, 50% Front Window l VMR V710 GM 19" l JL 10W7, Pioneer Bt-920, Focal Components l V1 l
    Arnold Palmer Club Member #11
    For Sale: OEM Motor mounts (PM price), Aux Air Pump, PS Cooler, Stock Air Box (w/o top ram air intake snorkel piece)
    Quote Originally Posted by mbgt72 View Post
    My battery is already in the trunk so I do not have that option with the RS4.
    Running off the IDC,RPM and Vacuum indicators is actually more precise than running off the MAF if I am not mistaken. The S4 version 1 will be boost control only the S4 version two will be for FSI that is N/A according to the dude I spoke to.
    Nashville, TN
    Oh yea, I knew that but just wasnt thinking about what car you had. Oh well, one more perk to having an RS4 huh. Is there anything that is in that location stock? Just wasn't sure. Thanks for the info and I'll look into it some more.
    Also on that kit, if we do go to a forced induction platform, what would have to be changed over for the meth to work with the boost controller? I don't want to buy one kit just to go to another if I end up boosting later on.
    New Member Steadyb has an average reputation Steadyb's Avatar
    Jun 2011
    Retsujou did you ever install a Water/Meth kit? If so which and what did it do to performance/air temps?
    I plan to inject my RS4 a few weeks after SC'ing in order to measure the temp before & after. Most kits come with a 250gph pump but injector sizes seem to be all over the place. Wondering if anyone knew a formula to figure out what size injector to use? I was set on this system but now I need to compare it to the LMS kit -
    The Best Water injection system and water methanol injection systems at AlcoholInjectionSystems.com
    Anyone with a supercharged RS4 getting excellent results from a certain kit or running a system with Staggered and/or separate Injection points? Happy Motoring, http://www.flickr.com/photos/63360839@N07/5763209880/
    like a michevious badger
    koolade9 has an above average reputation koolade9's Avatar
    The 480
    Quote Originally Posted by Steadyb View Post
    Anyone with a supercharged RS4 getting excellent results from a certain kit or running a system with Staggered and/or separate Injection points? Happy Motoring, RS4-FRONT (2) | Flickr - Photo Sharing!
    Which S/C kit did you install?
    ...wait for it....
    '07_RS4|Stasis|Alcon|Swift|Ohlins|Stern|Recaro|034 Motorsport|JHM|Vorsteiner|ADV|SRP|Hotchkis|Enkei|
    X2.
    2007 RS4: // K&N drop in // Hawk HPS up front Stop Tech in the back // DTH CF Engine Cover // JHM L/W FR & RR // Magnaflow X //TUBI RUMORE // JHM Intake Spacers // 30% TINT // Hotchkis F&R Sways // Stern Links //Stoptech SS // Apikol Red Diff Mount // 034 Trans Mount // HOEN H11 Fogs // LED City/DRL & Interior // ECS Clear Side Markers //
