Here is some data I’m sharing with everyone. My intent is to dyno my car before the valves are cleaned, then right after the valves are cleaned and finally one more time once I have the JHM tune + piggies installed.
Today I had the first step done. My numbers are UNCORRECTED and I have a print out with the results. The shop says they normally use 1.15% as a correction factor (the lower of the two options) but because their weather buddy thingy that indicates ambient temp/bar pres etc is broken they are leaving everything uncorrected. I’m also sharing video for your viewing pleasure. The numbers themselves are not that important, the real fun stuff will come to light once I get the second & third runs done. Then we’ll be able to compare deltas etc. I realize that this isn’t an exact science because I’m not in a temp controlled cell and there will be some minor ambient temp changes most likely. This testing should still be fairly accurate.
Keep in mind there are no dyno tricks taking place, the third party dyno facility has no vested interest in my numbers. They are not doing the valve cleaning nor are they the ones who will be installing my JHM tune. With that said, here are the details from today’s dyno pulls:
Plugged in the facilities address into a weather/topical map site & got the following info based on when I was at the shop:
Altitude = 89.65 feet above Sea Level (give or take)
Time = 3:46PM
Ambient temp = 59 outside – roughly 66 inside
4 or 5 pulls, all done in 4th gear iirc. First 2 or 3 pulls were done with the ESP partially off (accident on operators part) and the “S” mode button OFF. Last pull was done with ESP full off and “S” mode button ON. I'm not implying the "S" button does a damn thing for the dyno, just sharing what took place. I am basically stock – only mods (listed in sig) are the K&N drop in filter and the Tubi mufflers. Vids & scan of dyno chart below:
Scan is of the 3rd vs. 4th (last) pull I believe.
Videos: (I officially suck at trying to trim/crop videos. I helped you guys out a little by adding music over the commentary...well most of it anyway. Of course I left the pulls themselves raw with no music during the pull so you could hear the exhaust. Yes my car is filthy, I'm sick as a dog right now and couldn't muster the energy to wash it today. The vids do no justice to the actual sound. Probably because I'm using a Flip.)
Fun starts at 1:55
[ame]http://www.youtube.com/watch?v=uhde7V_H-Bc[/ame]
[ame]http://www.youtube.com/watch?v=4GmIzCKPSgQ[/ame]
Fun starts at 1:13
[ame]http://www.youtube.com/watch?v=lPz8CzYPnMk[/ame]
[ame]http://www.youtube.com/watch?v=ozKPpTvM7FQ[/ame]
[ame]http://www.youtube.com/watch?v=swEijGa7gg8[/ame]
Ideally I'd like to take it to the track to measure against the three variables too but it's not realistic for me at this time. If that changes however, I'll post the numbers.
That's it.
Oh-One Aye-Six Fat-Body Four-Two
Austin
2007 Audi RS4
2007 Audi RS4
That is a long time to not drive her. I hear ya on the other vehicles. I sold my 'extra' ride right around the same time I bought this car. I rarely use the wife's SUV and I'm a bit spoiled because if I ever need to borrow a pick-up or a towing vehicle I can via my brother. His driveway and garages are like a dealership lot lol. He has many vehicles...
