Results 1 to 7 of 7
Thread: Save 10% on ALL Amsoil Products!
    Euro Addiction Advertiser Amsoil has an average reputation Amsoil's Avatar
    Sep 2011
    Default AMSOIL Products at Discounted Prices
    Save on ALL Amsoil Products
    AMSOIL, the leader in automotive synthetic lubrication, produced the world's first API qualified synthetic motor oil in 1972. Trust the extensive experience of AMSOIL The First in Synthetics® to do the best job protecting your engine.
    AMSOIL European Car Formula Synthetic 5W-30 Motor Oil
    AMSOIL European Car Formula 5W-30 Synthetic Motor Oil provides exceptional performance and protection for high-performance European vehicles made by Volkswagen, Audi, Mercedes-Benz, BMW, Porsche and more. Its low-viscosity formulation maximizes fuel efficiency without compromising engine protection, while meeting strict European performance requirements for gasoline and direct-injection diesel engines designed for low-viscosity oils. Formulated with low sulfated ash, phosphorus and sulfur (SAPS), AMSOIL European Car Formula 5W-30 Synthetic Motor Oil complies with modern emissions systems to provide optimum life and performance.
    Stay-in-Grade Performance
    Sophisticated European engines subject oil to severe operational conditions. Oils must demonstrate excellent high-temperature/high-shear (HT/HS) performance to maintain viscosity and provide adequate engine protection. AMSOIL European Car Formula 5W-30 Synthetic Motor Oil is engineered to stay in grade despite rigorous operation throughout the extended drain intervals European automakers recommend. Formulated with a select additive package and shear-stable synthetic base oils, it meets strict ACEA and VW HT/HS requirements to provide outstanding wear protection throughout the entire drain interval.
    Low-SAPS Formulation
    Excessive sulfated ash, phosphorus and sulfur (SAPS) in motor oil can harm modern exhaust treatment devices. Diesel particulate filters (DPFs), for example, require low-SAPS motor oil to resist filter plugging. AMSOIL European Car Formula 5W-30 Synthetic Motor Oil’s low-SAPS formulation promotes optimum emissions system performance and life, allowing reduced maintenance costs.
    Maximum Fuel Economy
    AMSOIL European Car Formula is engineered with a lighter 5W-30 viscosity and friction modifiers to reduce friction for increased energy through-put. It minimizes internal engine drag, providing an alternative for motorists currently using heavier-grade oils, but who desire maximum fuel efficiency.
    Enhanced Turbocharger Protection
    Turbocharged Direct Injection (TDI) engines commonly used in European vehicles require thermally stable oils that resist deposit formation and provide turbocharger cooling. Thermally stable oils help keep oil passages clean and promote fluid circulation so turbo bearings stay cool and lubricated.
    AMSOIL European Car Formula 5W-30 Synthetic Motor Oil provides protection and performance for TDI systems in all temperature extremes. Its low pour point protects turbochargers against oil starvation and ensures rapid oil pressure in sub-zero conditions, while its thermal stability withstands high-temperature/high-RPM breakdown to resist deposit formations that can starve TDI systems of lubrication.
    Available:
    Per Quart:
    Case (12 qt):
    5-Liter:
    Case (2 5-L):
    AMSOIL European 100% Synthetic 5W-40 Motor Oil
    AMSOIL European Car Formula Synthetic 5W-40 Motor Oil (AFL) is specially formulated for the lubrication needs of modern European gasoline and diesel cars and light trucks. Formulated with advanced AMSOIL synthetic base stocks, premium additives and a 5W-40 viscosity rating, AMSOIL AFL is the preferred oil for virtually all European automobiles, especially turbo-charged models. It is one of the only oils in North America to be recommended for the latest specifications of all three major European automakers - Volkswagen (Audi), BMW and Mercedes-Benz - and the latest North American API specification. AMSOIL European Car Formula is highly versatile for multiple applications.
    Maximum Engine Protection
    AMSOIL 100% Synthetic European Car Formula contains high quality anti-wear additives and surpasses the tough ACEA oil specifications for high temperature/high shear viscosity. It provides outstanding protection in high RPM, hot running engines and delivers dependable long-term performance for the extended drain intervals set by European automakers.
    Superior Engine Cleanliness
    The excellent oxidation stability, heat resistance and detergency properties of AMSOIL Synthetic European Car Formula keep engines clean. It is specially designed to prevent sludge and varnish deposits for reduced oil consumption, extended engine life and maximum overall performance.
    Minimizes Exhaust Emissions
    AMSOIL European Car Formula is designed for newer vehicle emission control systems. It meets current industry and vehicle manufacturer requirements for long life protection of gasoline vehicle catalytic converters and diesel particulate filters (DPF).
    All Season Performance
    The broad 5W-40 viscosity rating, low volatility (burn-off) and wax-free nature of AMSOIL Synthetic European Car Formula make it excellent for hot and cold temperatures. Engine wear is reduced, oil thickening is controlled and vehicles start easier in cold temperatures.
    Available:
    Per Quart:
    Case (12 qt):
    5-Liter:
    Case (2 5-L):
    Interested in saving more?
    Become a Preferred Customer and save 20%-25% on ALL PRODUCTS! PM Me for more information
    Buy Amsoil Online
    PM us for Direct Discount prices or to become a Preferred Customer and save 20-25%
    Sep 2011
    Default Transmissions, Transfer Cases, Rear Differential and Brake Fluids
    AMSOIL Synthetic Manual Transmission and Transaxle Gear Lube
    AMSOIL Synthetic Manual Transmission & Transaxle Gear Lube is a premium blend of the finest synthetic base oils and advanced, high-performance additives. It is formulated specifically for maximum protection in demanding manual transmission and transaxle applications where an extreme-pressure GL-4 gear lube is specified, including those where high-horsepower/high-torque engines and towing or heavy loads increase transmission stress.
    AMSOIL Synthetic Manual Transmission & Transaxle Gear Lube helps prevent the thinning effects of mechanical shear. It is formulated to maintain its viscosity and superior film strength for consistent, long-lasting wear protection. Synthetic Manual Transmission & Transaxle Gear Lube excels in hot and cold temperature extremes that exceed the limits of conventional mineral oils. It protects against rust, keeps seals soft for long life and is compatible with brass synchros for smooth synchromesh shift quality.
    Available:
    Per Quart:
    Case (12 qt):
    AMSOIL Synthetic Multi-Vehicle Transmission Fluid
    AMSOIL Synthetic Multi-Vehicle Automatic Transmission Fluid (ATF) is engineered to outperform conventional automatic transmission fluids and exceed the performance requirements of most North American, European and Asian vehicles. This sophisticated formulation provides outstanding performance and protection in the severe operating conditions of today’s most advanced transmission designs. Automatic transmissions have become increasingly complex as vehicle manufacturers strive to improve efficiency while satisfying consumer demands. Smaller, smoother-shifting transmissions with longer fluid-life capabilities and heavier load capacities are now standard in modern transmission design. Traditional ATFs, however, are unable to meet these extreme requirements, and new fluids have emerged with each new advancement in transmission engineering. AMSOIL first introduced a synthetic automatic transmission fluid in 1980 and remains the leader in transmission fluid quality. AMSOIL Synthetic Multi-Vehicle ATF is formulated with the highest-quality synthetic fluids and additives. It exceeds the most stringent industry standards and is recommended for a wide range of transmissions. AMSOIL Synthetic Multi-Vehicle ATF reduces confusion, misapplications and inventories. It eliminates the need for costly and suspect “one-treatment-covers-all” additives. The quality and performance of AMSOIL Synthetic Multi-Vehicle ATF is guaranteed.
    Fully Fortified
    • Anti-wear/extreme-pressure agents (extend gear life)
    • Durable friction modifiers (anti-shudder)
    • Anti-oxidants (extend fluid life)
    • Seal conditioners (reduce leaks)
    • Detergents and dispersants (keep clean and control deposits)
    • Corrosion inhibitors (control rust)
    • Anti-foam agents (improve hydraulic function)
    Exceptional Hot- and Cold-Temperature Performance
    Thermal Stability – Hot temperatures are no excuse for poor reliability. Naturally heat resistant and heavily fortified with anti-oxidants, AMSOIL ATF exceeds the most demanding oxidation requirements. AMSOIL ATF delivers outstanding protection against sludge and varnish deposits that clog narrow oil passages and contribute to clutch glazing. Transmissions can operate hotter and longer with AMSOIL ATF than with conventional fluids.
    Cold-Temperature Fluidity
    Cold, thick automatic transmission fluid lengthens shift times and reduces energy efficiency (fuel economy). AMSOIL Synthetic Multi-Vehicle ATF is waxfree and delivers extraordinary cold-flow properties (< -60°F pour point). Shifting is more responsive, energy efficiency is improved and warm-up times are reduced.
    Outstanding Wear Protection
    Varying speeds and loads causes torque multiplication and extreme stress on gears and bearings. To prevent wear damage consistent with low-quality fluid and ruptured fluid film, AMSOIL formulated Synthetic Multi-Vehicle ATF with high film strength (shear stability) and premium anti-wear/extreme-pressure additives (boundary film barrier). AMSOIL Synthetic Multi-Vehicle ATF protects transmissions during severe-duty service.
    Friction Durability
    Today’s transmissions are smaller and must withstand higher horsepower and torque while delivering smoother shifts, all with longer fluid life recommendations. AMSOIL Synthetic Multi-Vehicle ATF is formulated with friction modifier additives that deliver outstanding clutch-holding capacity (static friction), torque-transfer ability (dynamic friction) and anti-shudder properties (slipping torque converter clutches).
    Extended Fluid Service Life
    Most drivers are unaware that transmissions commonly operate under severe service and require shorter fluid drain intervals. AMSOIL Synthetic Multi-Vehicle ATF is a long-life fluid capable of extended service intervals. It provides an extra margin of protection, especially when fluid change intervals are missed, during heavy use and even during abuse. Drivers can count on AMSOIL Synthetic Multi-Vehicle ATF to provide protection beyond conventional fluids.
    Available:
    Per Quart:
    Case (12 qt):
    Gallon:
    Case of 4:
    AMSOIL Series 600 DOT 4 Racing Brake Fluid
    AMSOIL Series 600 DOT 4 Synthetic Racing Brake Fluid use pure base stocks and robust additives to combat boil-off and the effects of water contamination more effectively than conventional brake fluids. AMSOIL Synthetic Brake Fluids deliver superior high-temperature performance in auto/light truck, high-performance, racing and powersports applications.
    CONTAMINATION
    Water contaminates the brake system by seeping through microscopic pores in flexible brake lines and seals and through the reservoir fill cap when opened. Once inside, it quickly works to corrode brake parts, lines and seals, leading to eventual system failure. AMSOIL Synthetic Brake Fluids keep water in suspension, slowing its corroding effects. Their superior formulation lubricates and protects intricate braking components despite the inevitable water absorption associated with braking systems, delivering longer-lasting performance compared to conventional fluids.
    BOIL-OFF
    The extreme pressure and high heat common to braking can push conventional brake fluid beyond its boiling point, causing it to vaporize, or “boil-off.” Even more problematic, water contamination can drop the boiling point of conventional fluid below safe standards, accelerating the rate at which it boils off. This leads to a spongy or unresponsive feeling in the brake pedal. In contrast, the unique chemistry behind AMSOIL Synthetic Brake Fluids push their boiling point temperatures well beyond Department of Transportation (DOT) standards even when contaminated with 3 percent water (see chart). They maintain a stable viscosity over a wide temperature range and flow easily at the highest pressures generated in today’s automotive brake systems to deliver consistent, safe braking. AMSOIL Series 600 DOT 4 Synthetic Racing Brake Fluid features a wet equilibrium reflux boiling point (Wet ERBP) nearly 100°F higher than the DOT minimum, making it the ideal choice for high-performance cars, motorcycles and vehicles used for towing.
    Available:
    Per 12oz:
    Case of 12:
    Buy Amsoil Online
    Sep 2011
    In addition to Oils and Fluids we carry a full line of Mothers
    AMSOIL INC., The First in Synthetics®, is expanding its product line and introducing the addition of Mothers® Car Care Appearance Products. The Mothers line of products is divided up into four primary categories with additional supplemental products offered as well.
    Mothers® Product History
    The Mothers® Polishes-Waxes-Cleaners was founded in 1971 as a family owned and operated business. Over the years, Mothers® has improved its core technology in correlation with changes in paint technologies and has always offered premium car care products that span most all markets. The people at Mothers® firmly believe that the time people spend cleaning their vehicles is an investment in the health and beauty of those vehicles and, because of this philosophy, they have dedicated decades to perfecting their science and bringing consumers the highest quality products. There is no shine like Mothers®.
    Mothers® Products
    Airborne contaminants, corrosive pollutants and harsh environmental conditions can all contribute to the premature aging of a car's paint. Regular washing and waxing can easily make the difference between a long lasting, luminous glow, or a dull, dumpy finish. Proper vehicle maintenance involves cleaning paint and keeping it clean, which is a much smarter choice, in the long run, than trying to repair distressed, damaged paint. Mothers® offers a unique and wide product line that includes everything needed to clean, polish and care for vehicles.
    The Mothers® product line is divided into four distinct categories: Reflections®, FX, Power Products and California Gold/Mothers Original. Each unique product category helps discerning consumers decide what types of products best suit their vehicles as well as their individual outcome intentions.
    Mothers® Reflections®
    Mothers® Reflections® is for discerning automotive enthusiasts and offers a refined blend of high-tech and high-class products. These products leave vehicles looking clean and classic without looking too glossy or “wet.” The Reflections® line was developed specifically for the complex finishes found on cars today and offers benefits such as deep gloss, long lasting durability and high shine, while still being quick and easy to use.
    Mothers® FX
    Mothers® engineered the FX line to be the most sophisticated, state-of-the-art products available today. The FX products are designed for “next generation car enthusiasts” that enjoy a very high gloss, “wet” look for their vehicles. These products also offer unsurpassed protection along with their high aesthetic appeal. The products on the FX line are incredibly quick and easy to apply, adding to their appeal for many who don’t have a lot of time to spend on their vehicles.
    Power Products
    Mothers® Power Products are the first and only car care formulas specifically designed for consumer machine (random orbital, rotary and dual-action) application. These products were created from the start to be used with power buffers, unlike other products that are designed for hand use but later modified to be machine compatible.
    Mothers® California Gold®/Original Products
    Mothers® California Gold®/Original products are optimal for detail-oriented vehicle owners who have time for a weekend clean-up and detail jobs. These products are ideal for use for car shows or other opportunities to show off the true beauty of a vehicle.
    Mothers® Marine Products
    Mothers Marine Products are surface care formulas specifically designed for the demands of marine applications. Special formulation makes these products safe and easy to use on all marine equipment.
    PM Me for pricing on all Mothers Products. Preferred Customers save 20-25%!!
    Buy Amsoil Online
    Sep 2011
    Your discount is not limited to only the European line of oils. If you wish to purchase OE, XL, Signature Series, Z-rod or Dominator series oils PM me. We have everything in stock and ready to ship! If you see it on Amsoil.com you can buy it at a 10% Discount or 20-25% if your a Preferred Customer!
    PM or Email me for more information: Amsoil5001506@gmail.com
    Buy Amsoil Online
    Sep 2011
    TTT. Just got a new shipment of oils in. These are ready to ship to your door!
    Buy Amsoil Online
    Sep 2011
    Bump
    Buy Amsoil Online
    Sep 2011
    TTT
    Buy Amsoil Online
